Potable Water Valves
I'm designing a potable water tank farm and I'm trying to determine whether or not the valve I want to use are acceptable. Typically I design B31.3, 31.4, and 31.8 piping systems so potable water design is foreign to me.
I know NSF 61 and AWWA have material requirements for valves. What other codes and standards cover valves for potable water service?
RE: Potable Water Valves
Hi
WRC ( Water Research Council UK ) approved valves, materials &  coatings are a good place to start to determine the correct selection of valves for potable water.
Typically, 316 stainless steel and certain types of copper alloys are acceptable, along with UPVC and ABS plastics.
Cast iron bodied valves are acceptable with the correct internal epoxy coating. Seal materials such as EPDM rubber have to be individually approved and certified by an approval body such as the WRC to ensure that the particular 'recipe' for that elastomer is acceptable. Virgin PTFE is generally accepted as inherently acceptable. But it really depends in which country you plan to build the plant, as most have the own local by-laws governing materials for potable water
Hi AKBen,
There is a world of difference between the standards you are used to and the water industry. Suggested vendors are Tyco & Crane for the water industry. Check out their websites.
  These days butterfly valves are more prevalent than the wedge gate valves, although I do prefer the gate valve.
In Australia the WSAA has standards that cover these valves until superseded by an Australian standard. Refer https://www.wsaa.asn.au/Publications/NationalCodes/Pages/WaterIndustryStandards.aspx. They also have codes of practice.
Jeffvalve has a good description of your choices, most important (as also illustrated by stanier) is your localization.
Commercially there is a fierce competition among producers and suppliers to this type of application, and prices and quality will vary, as well as troublefree standtime.
Preferred types of valves, and brands will vary according to sizes, pressures, local regulations and local competition. (Give more data and get more directadvice regarding brands and types)
You may well use cast iron or nodular cast iron valves, properly coated with approved coating and sealings in SS pipelines. I would strongly recommend price/lifetime comparisons before choice anyway.
Selection between gatevalves and butterflyvalves will depend on size and pressure class.
If butterflyvalves are selected, double eccentric valves should be compared to centric on price/troublefree lifetime basis.
While butterfly valves (BFV) and other types with virtually permanent obstructions to the waterway indeed have their places, it should be remembered that any selection of these valves over gates means that that disk is always going to be there, and therefore be an obstruction to trying to pass whatever/any sort of sizeable equipment (or inspectors) through same.  This would include pigs sometimes used to remove construction debris or contamination in the present or future, as well as many flavors of condition assessment equipment becoming en vogue now in some areas.  [I suspect some young engineers might not realize such subtle convenience, or perhaps in some cases arguable need, until of course they try to crawl into or out of a confining line with limited access and a butterfly disk in the way!]
I should have probably mentioned as well that while it might be argued insignificant in many applications, if used in normally open shut-off valve applications full open butterfly valves are generally regarded as having more head loss/friction to pumping etc. flow than full open gate valves (again as a result of the disc in the way of the flow).
Another downside of butterfly valves is that unless fully flanged they cannot be relied upon to isolate a section of line when removal is required. Butterfly valves are not considered a source of isolation by some authorities with rigid double isoation policies.
When it comes to check/reflux/non return valves becareful in there selecction as check valve slam can cause untold damage and loss of utility to a system. Refer to Fluid Transients in Pipeline Systems ARD Thorley or Pressure transients in Water Engineering Ellis.
Dual flap check valves are cheap but are considered agricultural in nature. Non slam valves by Noreva, Mokveld and thers need to be considered by your analyst. Ensure that the reverse velocity and deceleration are specified to the check valve suppier for pump stop.
Air valves are another difficulty. The legacy products on the market may actually increase transient pressures. Refer www.ventomat.com for some good technical papers on these valves. Being from the petrochem industry you would not be famiiar with use of air valves. Ventomat provide softare for sizing and location of air and vacuum release valves.
You should be able to get a copy of Advanced Water Modelling of Distribution Systems by Haestad. This is now a Bently product. They were giving these CDs out at exhibitions. Let me know if you cannot locate a soft copy?
