'g' loads during transportation
Hi All,
Does anybody know (or suggest a reference)what the 'g' loads normally are during transportation on road.
We are have problems while transporting our unit and therefore would like to analyze the structure per those 'g' loads.
Nandviks
Nandviks
RE: 'g' loads during transportation
Trucks are in danger of rolling at somewhere around 0.3 g lateral acceleration. Passenger cars lose grip around 0.75 to 0.85 g.
The advisory speeds on curves, using the method in the current US MUTCD, result in lateral acceleration of ~.2 to .25g.
Many curves still have advisory speeds set using the older method, which was base on the cornering capabilities of American sedans of the 1930s, and are therefore even more conservative.
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
Could you please explain the basis of your calculations, ...also were they vertical or lateral acceleration ?
