Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks for a great forum. My problem was answered just by scrolling through previously solved problems. Great service!!..."
Geography
biomech21 (Mechanical)
3 Sep 10 12:48
I am designing a heat staking fixture (inserts brass
inserts into thermoplastic parts with the aid of heat) for
the injection molding industry.  The staking procedure
requires temperatures of around 300 degrees F and the
machine can handle a max of around 1000 degrees F as long
as insulation is present between the heated probe tips and
upper carriage.  This insulation is generally 1" thick,
but the identity of the material is kept proprietary by
many manufacturers.  The insulation must be MACHINABLE and
able to withstand approx. 100psi.  Does Macor sound like a
probable alternative?  Does anyone know of a cheap material
that should be able to perform well in these conditions.
I've attached a photo of a similar fixture for reference.
The insulation is the layer sandwiched between the two
aluminum plates.
Thanks!
http://files.engineering.com/getfile.aspx?folder=12589af1-a640-4a64-8575-18
unclesyd (Materials)
3 Sep 10 13:58
Ma cor will work. To get something reasonable in cost  you are going to have to limit your upper temperature.
Here is Superfiretemp that we use by the truck load for insulation on polymer process at 600°F. Readily available in 1" thick material.
http://www.monoco.com/Super_Firetemp.asp
Here is a material that I've used from Cotronics.
http://www.cotronics.com/vo/cotr/cm_machinable.htm
Another material you may want to checkout is MICA
Ceramicguy (Materials)
7 Sep 10 11:20
The insulation in the photo looks like glass bonded mica.  It is produced by several vendors throughout the world and is sold by many resellers.  The vendor I am most familiar with is Crystex Composites (the old Mykroy Micalex).  They have three grades, 400, 500 and 1100 that correspond to maximum use temperatures in degrees F.  All are readily machinable using standard machine shop practices.  They are significantly less costly than MACOR.
Crystex is located in Clifton, NJ.  The telephone # is 973-779-8866.  Resellers include Aremco Products, Cotronics, and McMaster Carr to name a few.
This is a fairly massive insulator.  There may be a tendency for thermal stress failure over time.  If this is a problem, you could substitute Grade A Lava.  It will perform as an electrical and thermal insulator and have the stiffness necessary for your staking operation.  It is also known as pyrophyllite.  It is a naturally occuring aluminum silicate mined in large quantities worldwide.  Any of the resellers listed above also supply this material.
If it were my project, I would start with the glass bonded mica.  It is readily available, produced domestically, a good thermal and electrical insulator and the easier of the two materials to machine.
Bruce
www.accuratus.com
Close Box
Join Eng-Tips® Today!
Join Us             Close
