Solidworks Add-in...
HI!!
I want to do a solidorks add-in showing a toolbar in VB, with the new interfase SWaddin and the command addtoolbar3.
But I've some problems with the function addtoolbar3 and addtoolbarcommand.I don't know how to get handles of bitmaps(addtoolbar3),and how to put the name of my callbackfunction(addToolbarCommand).
Is Someone who can send a bit of code in order to help a poor guy working during hollidays to pay his studies....
RE: Solidworks Add-in...
If you tell me your email address I can send you an example.
MHendler
This sounds hopeful. I did not know, that Visual Basic could add a button to the tool bar. I know about the macro tool bar. Can you create other buttons on the SolidWorks tool bar?
brad_johnson@dstoutput.com
Bradley
I would like to take a look at your example file too...I'm tring to create one here myself, but not having any luck. You can send it to: bolen.16@osu.edu
Ken Bolen
I'd appreciate a copy as well:
eearnst@accuray.com
Eric
I would also like to take a look at your sample.
Thank you.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
geoffg@wesgar.com
Cheers,
Could you resend the code? Somehow I never received it.
Bradley
Could anybody send also me the code?
I have problem on my add-in
hToolBar = pSldWorks.AddToolbar3(swCookie, "My ToolBar", 102, 101, 5, swDocTemplateTypeASSEMBLY)
pSldWorks.AddToolbarCommand2 swCookie, hToolBar, 0, "Toolbar_Callback", 0, "titolo ToolBar", "pick me"
thank
Massimiliano
lordofthegears@hotmail.com
caeserean
C.U. Mech. Eng. Dept.
http://www.websamba.com/onderunver
Tom
cheng1222@yahoo.com
Thanx,
Wim Vancoillie
Chris Gervais
Mechanical Designer
American Superconductor
there's so much interest around your piece of code that you should post it into FAQs. I would like to take a look at your code, too.
Andrew
Rawhead Rex,
can you be alittle more specific, pls.
A.
Here is the link to the SolidWorks API Support website Code Example section. I looked again and specifically, the code example (in VB) is a Visual Basic COM DLL addin project. Again I don't know whether or not this helps anyone out but on the outside chance that it might stimulate some ideas I figured it worth mentioning. It's certainly something that I plan on giving serious consideration to make use of.
http://www.solidworks.com/api/index.cfm?template=CodeExamples
Chris Gervais
Mechanical Designer
