Internal Baffle Welding to Pressure Boundary
I'm designing a vessel with SA-240 304L and a SA-240 304L internal baffle.
I have the weld detail called out for a 3" on 6" pattern staggered both sides. Our customer would like it fully welded both sides. Is there any code reason why a 3" on 6" pattern both sides is not acceptable?
3" on 6" is acceptable for vacuum rings etc.
Thanks!
Thanks!
RE: Internal Baffle Welding to Pressure Boundary
Looks like we are going to get the customer to pay for the extra work involved. I can see if it wasn't staggered both sides to get a full weld you could see stress concentration from the unsupported area under pressure.
With it staggered the full weld both sides it seems a bit overkill.
Thanks again.
The extra bit of fillets far outweigh the potential corrosion issue.
There are some guidelines for baffles contained
