"LT" field in revision table
I have a drawing from another company that I need to revise. The revision table contains the following columns: NO., LT, REVISIONS, DWN, CHKD, DATE.
What in the world does LT stand for? Thanks!
RE: "LT" field in revision table
It might be any of these
Hmmm, only one that might make sense is Lead Time...
Could be Lot?
What about Letter as a shortened notation for Zone Letter?
Ben Loosli
Quote (MintJulep):
   I vote for Looney Tunes.  It is the only way the users of mysterious acronyms are going to learn.
               JHG
I guess it could be zone letter, but what if the revision spans several? Seems pretty silly... :/
Do you have an example of a filled in revision block or just the blank one?
Ben Loosli
Lead Technician?
I have seen lots of crazy stuff thrown onto rev tables and BOMs.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
I'm with drawoh. Get your company to settle on "Lost Time", put a "yes" in the box below it, then bill the customer for however long you spent trying to figure out what they meant. That'll definitely teach 'em.
Powerhound, GDTP T-0419
Engineering Technician
Inventor 2010
Mastercam X4
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
List? As in Associated List, Parts List, Data List, etc. to indicate the document affected.
Is your customer heavy on Lists?
Getting back to looslib's question.  Is there any entry in the LT column?
Any reason you can not ask the other company?
Ted
There are no entries in the LT column. I suppose that WOULD give some insight.
Indeed, I don't know the meaning of LT on the revision table column.
Is it possible LT for Locational Transition Fits ? It's one of the Preferred Limits and Fits for Cylindrical Parts ANSI B4.1-1967 (R2004), the others are :
Running and Sliding Fits (RC)
Locational Clearance Fits (LC)
Locational Interference Fits (LN)
Force Fits (FN)
SeasonLee
Quote (SeasonLee):
Is it possible LT for Locational Transition Fits...
   Good idea!  Mark the number of locational transition fits in the LT column, then don't tell anybody what you are doing.  If you have to wonder and guess, then the other company should have to wonder and guess.
               JHG
If there are no entries in the column and you do not get an answer from the other company, I would ignore it, just fill out the others.
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
