Need Minimum Clearance - 208V Bolts?
Does anyone know the the minimum clearance of open air 208v conductors?  I have an STS with B & C phase bolts that are too close together and I need to know how much space between I need.  Picture attached.
Couldn't find it in NEC 2008.
Thanks.
RE: Need Minimum Clearance - 208V Bolts?
I don't think that is addressed in the NEC.  The closest I know of is 366.100(E) in the 2008 code, but that section does not directly apply to your question.
It will be a manufacturing requirement or a testing lab's such as UL or ETL. Look up NEMA too.
By the way there is no picture attachment.
Rafiq Bulsara
http://www.srengineersct.com
One inch in air, two inches on an insulating surface.
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
