Hotwater tank elements
How do you test the elements in a domestic hot water tank to see which one is to be replaced?
RE: Hotwater tank elements
The procedure is in the manufacturers service guides, but should be simple for an electrical engineer, electrician, or plumber with a voltohmeter.
You should also check the other element and it connection to ground, if one has failed, the other may also need to be replaced. Follow the procedure by KSherlock then check from either wire connection to ground, if there is less than infinite resistance that element should also be replaced.
Hydrae
