Callout - Saved Settings
Anyone using the 'saved settings' in the callout function?
I would like to use it, but when I select the saved name, it puts the proper text into the box, but does not do anything to the font style or the size.  It seems to keep the default style, color, and size.
Is there anyway to make the saved settings different from the the rest of the style, which I don't want to change.
RE: Callout - Saved Settings
Create a new style as you want the callout to appear, then it will be one click to change any other callouts to that syle.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Beachcomber!  That is perfect.  It didn't even occur to me to try it that way, but for what I'm trying to do it works.  Maybe not as good as having the style changes in the callout dialogue modified by the saved settings, but better than having to change them individually.
Thanks!
Glad to help.
bc.
Quadro FX4600.
