pdf insertion
pdf insertion
pdf insertion
Hey everyone,
Is it possible insert a pdf file into a Acad drawing?  And if it is, how?
Much appreciated for your help!
Juiec
RE: pdf insertion
This is how I have done it, (not exactly inserting a PDF).
1. Open the pdf document.
2. Capture the image with some screen capture program (Snag-IT from www.techsmith.com works well)
3. Paste into the AutoCAD document.
At time I will take the captured image into a raster to vector conversion program.
RE: pdf insertion
Dear Juice,
You can connect the pdf file to an object in AutoCAD
using the HYPERLINK command.
Just enter the HYPERLINK command and select an object,
a dialog box will be opened and you can select the pdf
file using the "File..." button.
Click OK.
to recall the pdf file select the related object and
right-click. From the context menu select the command
    Hyperlink -> "pdf file name"
The pdf file will be opened.
Farzad
