shredder
shredder
Looking for ideas on a thrust bearing for a shredder machine w/ a 2-1/2 dia shaft. Shaft length is 30" w/ 15 mounted rotating chewing disks. We are shredding soils and clay at about 40 yds/hr. Would like a common HD bearing w/ low profile. About No. 80 drive chain on sprocket too.
Any ideas welcome.
Thank you
RE: shredder
Would like to know how to calculate which hydraulic motor to turn a 2-1/2 dia shaft at a length of 30",with 15 mounted rotating chewing disks for a shredder machine. We are shredding soils and clay at about 40 yd3/hr. we are also using a No. 80 drive chain on 12 to 19 tooth sprocket too.
Soils are about 80lb/ft3 density and loading is, well 40 yd3/hr
Any ideas welcome.
Thank you
RE: shredder
Mike Halloran
Pembroke Pines, FL, USA
