gauge table help
gauge table help
cannot get gauge table K values to affect part. i have copied and pasted the existing chart below in same file to accomodate the different gauges we use and k factors (all in one excel file). when i edit a k value on the chart it does not change the flat pattern. how are the charts supposed to be filled out and used. the help files do not explain .
RE: gauge table help
With the tables updated new bends would be layed out correctly.
"I think"
Hardie "Crashj" Johnson
SW 2010 SP 2.1
HP Pavillion Elite HPE
SolidWorks 2011 will have the ability to use real formulea with a default pulled from the DIN standard. This will hopefully be much more reliable than the way over-simplified K-factor.
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
