Dimension Numbering Macro
thread559-205851: 2007 inspection dim numbers
I found the thread referenced above which contains a macro for applying dimension numbers on a drawing. This works fantastically, except for one limitation - it applies dimension numbers to basic dimensions.
Does anyone know if there is a way to, within the macro, check if the dimension is marked as basic and, if so, not apply the dimension number?
RE: Dimension Numbering Macro
-handleman, CSWP (The new, easy test)
