importing images into NX5
I am trying to import an image in UG. I have the image in .tiff format. This is not something I normally need to do so I am not sure how to go about it.
is this possible?
sorry it not a more complex problem but this is not something I've ever needed to do before so I am not sure how to go about it.
is this possible?
RE: importing images into NX5
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.5.3 + TC8.1 Unified / NX7.0.0.9
Belgium
I can now sketch over the image in drafting
but how do I export the drawings sketch into modeling mode and use it there?
Activate the toolbar then goto Visual effects, choose the desired background, then hit the start shade button. This image you can export through the file - export menu - ...
as a jpeg, gif or tiff.... If you had applied materials on you model it will render to.
One remark, if you render the high quality image, you cant rotate or move your model anymore until you erase the shade.
Best regards,
Michäël.
Belgium
While in the Modeling module, go to...
View -> Visualization -> Raster Image...
...where you can select a .tif file as well as define the size of the image. What you will get is a planar sheet body with this image assigned to as a texture which you can then see when in the Studio display mode. Now you can define the Planar surface as the Sketch plane and sketch over the image.
As for moving a 'Drafting' Sketch to the model space, I'm not aware of any practical scheme for doing something like that.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I have recently found though that because it's difficult to scale the curve(s) or move them around when modifying the part model, it works much better if I make a separate solid model from the image sketch and then bring that into the final part. For example, something like a solid disc with an extruded logo shape on it. Think of it as looking like a stamp for stamping an image on paper. With the solid you can scale it, move it, and rotate it associatively much easier than a sketched curve. Use the Face Edges of the extruded logo to project or wrap or whatever on to your model.
I realize this may be a little confusing to follow. If you want some more clarification let me know. I wish I could attach a part but just about everything we do is proprietary.
Mike
that is exactly what I am trying to do...but I do not appear to have the licence to bring in a raster image.
It is possible to get vector curves from an image in some programs like CorelDraw, but I've always floundered pretty much when I attempted it. At a previous place I worked we always asked the art department girls to get us good curves with Adobe Illustrator, then we'd import them.
Sorry, I know that doesn't help you, but I'm at a loss at this point.
Mike
