conc 2-way flat plate
I want to learn how to design and detail the flat plate.
I need your suggestions as to the best source of reference material other than code. Thanks in advance.
RE: conc 2-way flat plate
Messing around with RAPT is an easy way to learn, and the manual is pretty helpful to...
If you are looking at PT slabs, do not rely on the ACI/PTI logic as a background to learn how slabs work as it is very misleading.
pwht1's original suggestion is a good one, as would be most RC design text books.
An expert is a man who has made all the mistakes which can be made in a very narrow field
