How to properly tap PSE for creating a "Per Part" JT ASM
For those in the audience that deal with generating "Per Part" JT Assemblies (one assembly JT with a folder of parts/sub assembly JTs) - has anyone developed a "simple" method of extracting the assembly structure from PSE (NX/Ideas) to be able to:
1)  Create the list that needs to be translated out into native JT form
2)  Create the correct part orientation and/or number of instances for each component and/or subsection
Seen more than a few "home brew" versions, but hoping to know if anyone at Siemens has a "Best Practice" method.
Thanks in Advance!
