480 voltage
480 voltage
what is the min. air gap needed to prevent 480 volt AC from arcing?
RE: 480 voltage
Your Dielectric Withstand Test uses 677 Vdc (or 479 Vac). If the test passes it will confirm that the smallest gap between exposed conductors in the cable is likely greater than 0.003 inches (0.08 mm). If the test fails you may have a gap less than 0.003 inches (0.08 mm). If the DWV test is done in helium then the test might detect a gap as large as 0.083 inches (2.11 mm).
RE: 480 voltage
RE: 480 voltage
RE: 480 voltage
