PRC-023 example worked out
Can anyone direct me to where I can find some PRC-023 example worked out so that I can verify that I am doing it correctly?
This is the only resource that I have been able to find anywhere and even though it is much better than the original PRC document, it is still rather vague.
nerc.com/docs/standards/sar/Relay_Loadability_Reference_09Jan07.pdf
In particular I am having problems with R1.3
Thanks in advance
Thanks in advance
RE: PRC-023 example worked out
http://w
Secondly: if you'll search on Google "PRC-023" you'll get more information.
