help.. Using Insight on a 64 bit Computer
Anyone running Solid Edge V19 using Insight on a 64 bit computer?
I can not get web folders to set up. Any ideas?
I HAVE 10 NEW COMPUTES DEAD IN THE WATER HELP PLEASE.
http://files.engineering.com/getfile.asp
RE: help.. Using Insight on a 64 bit Computer
Solid Edge ST2 SP5 on WinXP x64
You can run WinXp 32-bit on a 64-bit processor with Solid Edge 32-bit.
You can run WinXP 64-bit on a 64-bit processor with Solid Edge 32-bit.
You can run WinXP 64-bit with Solid Edge 64-bit.
Solid Edge 64-bit back in the day of v19 did not support Insight. You can keep all of your other 64-bit software, but you must install the 32-bit version of Solid Edge.
--Scott
http://wertel.eng.pro
Everything is working fine (mosty) I can draw and work with documents within insight fine. But, when I create a new document (even using save as) in insight it creates it as \\cass200\eng\prod\work\xxxxx.dft vs. http://cass200/eng/prod/work/xxxxx.dft
When you try to open them they say "this doc is not added to the library or save ass cannot generate indirect files list for this document".
Attached error
Thanks i am stressing out bad about this
I found in the insight documentation. Not to turn it off with x64 (that also what solid edge told me we don't have a service contract any more so they were not a lot of help)
Theodore
this is what i am using
do I need to add the \\CASS200\Engr\rd\work
and so on?
I am at loss.
