shear cone - rack leg
We have racks on slab on grade. The rack legs or posts has 3x3 inches steel base plates. We need to check if SOG will not shear out. Any idea. Can we use punching or two way shear method
RE: shear cone - rack leg
I have been involved in testing 6" unreinforced slabs for axial compressive loads.  A similiar sized baseplate resulted in measured deflections of less than 1/32" under a 40 kip load.  There were no visible cracks.
As a side note, we did have a relatively stiff subgrade.
