Nonlinear analysis iteration graph display
Hi everyone,
I am doing a non-linear analysis with contacts, non-linear elasticity and large deflection in multiple steps.
Upon solution I am getting a graph with "cumulative iteration number" on the X axis, convergence norm on the Y axis and a few lines jumping up and down. However, after a few iterations the graph stops working, only to resume on the next loadstep.
Why does it stop? Where can I control the settings of this graph?
Struct71
Struct71
RE: Nonlinear analysis iteration graph display
Firstly: check the compatibility of your windows with Ansys (right click on Ansys product Launcher- properties- compatibility) and change the compatibility to the highest version of windows. (At my computer is win 2000!)
Secondly: use the /gst,on command.
Hope that helps
Jalil
