Native Finite Element
I am kicking around the idea of doing some simple problems via finite element in Excel. A few questions:
- Is there already something out there done with just simple formulas or VBA?
- Is there way to increase the number of columns beyond 256? If I were to program it via formula, then I would only have 256 degrees of freedom, which is too limiting for the problem I am trying to solve.
- I can build the nodes and elements simply by geometry and describe them as rows in Excel. Is there a simple way to then send this to a solver?
- Any VBA code out there that could do something like this?
- Could I do a matrix inversion (i.e. minverse) by combining multiple matrices (i.e. 256x256 multiple times).
Just kind of thinking out loud/brainstorming at this point. Any thoughts or ideas? My rough guess is that I would need to invert a 2,000 x 2,000 matrix.
RE: Native Finite Element
You can create arrays in vba that don't have the column limit. You just can't send the full matrix to an excel sheet (unless you break it up first).
There may be some limits on size of matrices that can be handled by Mmult and Minverse (my excel 2000 has problems when you get up above 50x50), but those limits don't exist if you use the Alglib routines - some hints at Doug's website.
I would say, working with matrix algebra in vba takes some getting used to. You sort of have to build the tools or at least spend a lot of time getting the tools to do what you want. Not as easy as Matlab to build matrix equations... but certainly can be done.
(2B)+(2B)' ?
(2B)+(2B)' ?
I can think of many "better" ways to do it than in Excel to get an answer. But I am looking to create software that can be redistributed and easily used by anyone. This really limits the playing field. It would be part of a suite of tools that I am developing for composite structural analysis.
Excel is not very friendly for programming these types of the things. But the final product is "better" due to the user interface and the fact that almost everyone has Excel. Compared to a mathematical software or FEM software, I think most people would rather have an Excel file where they just data in some cells and get a result. The other options put a lot more burden on the end user.
Brian
www.espcomposites.com
Brian
http://new
The spreadsheet in the link does the matrix work in VBA, but earlier versions have "on spreadsheet" solutions, if you want to follow it through from the basics.
It's beams elements only, but it should be fairly easy to convert to plate elements.
You can also find Excel versions of some ALGLIB matrix routines, both VBA and compiled versions, which should be much more efficient than the routine I have used in the frame program.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Another aspect of using FE is never to use 3 noded elements as the results will be useless. If you can get an automatic mesher then use 4 noded or 6 noded (quadrilateral) elements.
By the way, excellemt spreadsheet Doug. The only suggestion I would make is to draw the deflected shape using the calculated rotations, as well as the translational displacements, to draw a cubic between the two nodes of an element. I've done it for 1D beams but not for 2D beams, yet.
Tata
We are on different pages here. You are talking about developing a robust FEM code. That is not my objective. I am looking for a simple solution and run times will be relatively short so optimization is not needed. As I mentioned early, I am familiar with the concept of bandwidth, etc. but again that is simply not necessary and would ultimately be more time consuming that it is worth. You are talking about something that would be done by FEM developer. Before I go that route, I would just pass the Excel mesh to a 3rd party solver and read the data back in.
As far as 3 noded tri's go, they are not "useless", provided you understand the pitfalls of such an element. This seems to be a myth that I have seen perpetuated for many years. Compared to other choices in advanced FEM software, a 3-noded tri might not be the best choice, but is is a viable element for the problem I am trying to solve. The problem with the 3-noded tri is that people may use it without understanding it's shortcomings and then blame the element when it fails to produce an acceptable result. In actually, it is just being used outside of it's acceptable domain. Anyway, that is getting off topic.
Brian
It's on the "to do" list :)
I have a splinebeam function that analyses continuous beams by fitting a cubic spline to a unit deflection at each loaded point, then scaling and adding the results so I will probably adapt that.
Doug Jenkins
I'm trying to follow your code but only being at the basic level of excel VBA am having trouble. Things like "selectranges reselect" and other terms are beyond me. The help section in excel is useless when you do a search for such stuff and google doesn't give much help from the other forums around. Do you recommend any books that describe these things that seem specific to excel rather than Visual Basic in general?
Tata
If you have time, I'd appreciate it if you could list where you found things that didn't make any sense to you, as I'd like to make the explanations comprehensible to people like yourself, who have a good knowledge of Excel, but not a detailed knowledge of VBA.
I might perhaps do a short series of posts on the best way to transfer data from the spreadsheet into VBA and back again. That's really the main area where my programs differ from straight VB, since I make little use of forms and other Excel specific objects.
Doug Jenkins
I'll put it on my to-do list to write a post going through that routine step by step (but my to-do list is fairly full, so it might be a few days before it appears :))
Doug Jenkins
