Linear/Circular vs Feature driven components
Basicly my question is pretty simple. Why not just skip the linear/circular patterns and just use feature driven. It has one advantage. For example; if I edit my flange from 12 to 14 bolts, my assy's bolts would update accordingly.
Just a thought...
Gz J
RE: Linear/Circular vs Feature driven components
I take it you mean linear/circular sketch patterns vs linear/circular feature patterns?
This has been discussed before. The general consensus is the feature pattern is the 'better' method. However, sketch patterns can be useful for component placement when creating a master layout sketch.
Feature driven will not rotate the parts,circular does.
Hardie "Crashj" Johnson
SW 2010 SP 2.1
HP Pavillion Elite HPE
I think I wasn;t 100% clear :) - What I mean is in an assembly. You put 1 bolt in your flange and then you want to fill up the rest. This can be either by using circ. pattern or use the feature pattern and take the circular pattern from the part.
Yes, you should use a feature driven pattern.  I cannot immediately think of any advantage to using linear/circular patterns.
-handleman, CSWP (The new, easy test)
