Pressure calculation
Hello all of you !
I need someone to confirm my opinion.
I have a strap of 10 mm thickness and 100 mm width that tightens an element. I know the tension force in the strap (T=30kN)and I want to know the pressure P resulting at the center of the element tightened.
You can see the problem in the attached file.
Thanks for your answer...
RE: Pressure calculation
strap stress = T/(wt) = pR/t ... p = T/(WR) ?
I would suggest the Von Mises-Hencky Theory were shear is rotated out of the model by Mohr's Sphere thus resulting in principle stresses. This can be directly compared to material yield, resulting in a computation on Factor of Safety. The mathematics can be a bit much for regular engineers, who are poor mathematicians at best, but the solution is quite elegant.
Therefore I will append the first of two papers discussing the subject.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
You have a restriction in hoop stress were the assumption is that longitudinal stress as the result of end cap reactions to pressure, and radial stress let the pressure vessel respond unrestricted. The hoop stress would introduce a variable term of stress into the equations that would need to be manipulated and isolated very similar to the case I have used for longitudinal boundary conditioning, case 2, page 3. The approach is exactly the same but using hoop stress terms instead of longitudinal.
Unfortunately I only did influence to torque and longitudinal stress restrictions. It is the method for analysis that is of interest to you, not necessarily the closed form solution set.
But this situation is very interesting, none-the-less.
Principal
Very interesting documents. Nevertheless I did not succeed to find a real answer to my problem. I didn't give enough information in my first post. I explain my situation again.
I have a stap that tightens a cylinder and a plastic element at the top. The axial load of the stapr is 30kN. It tightens the plastic element over all its surface. I want to calculate the pressure on the plastic material resulting from this tightening force... Is it only a matter of force projection ??
I'm only a trainer in a little French company...
You can see the problem in the attached document.
Thanks a lot for your availability...
I just want to know what do you call "W" and from where comes your formule... ?
Thanks a lot
Your file cannot be opened on my end, "png" is unrecognizable. Can you "pdf" it?
Principal
integration(wprcos@d@)limits -.5 phi to =.5phi.yields the vertical component of force, viz
2wprsin(phi/2)=2Tsin phi/2. Since the sin terms drop out, we have
T=wpr
which could also be done over an infintesimal arc,d@
wprd@=Td@
T=wpr
w=width strap
phi wrap angle
cockroach, I attach the pdf file to enable you to open the file and see the picture of my problem. If you have any suggestion, I wait for it...
Thanks again !!
Vinsce.
Unfortunately, in my case the pressure can't be uniform on the plastic. So if you can tell me how to consider it, it will be great...
Thanks a lot
If so, then the solution I propose is eminently correct, since it derives from force equilibrium over an infinitesimal arc, and coincidently is the same solution as a thin walled cylinder.
Moreover, if you don't allow a constant tension, then the solution is still correct for local values of T.
I can't apply my tension constantly, I must divide it in ten components since it's important to have a strong effort at the center of the plastic element. The strap is applied on 10 surfaces whose the tangents change of value and the projection angle too. So I don't know by what surface I must divide my tension effort to obtain the consistent pressure on each surface...
I attach a more explicit file to show you the problem.
Thanks !
how is the tension in the strap going to change ? friction ?? you can look at you tangent faces and see if they are a reasonable approximation for an arc.
The arc has a 110mm radius...
Have you any suggestion concerning the non constant pressure applied ??
maybe have the strap apply a radial load to the plastic piece at each facette intersection, ie the resultant of the strap tension on either side of the "kink". and this is reacted by a pressure on the plastic piece. it doesn't have to be uniform, but it does have to be equivalent to the strap force.
clear as mud ?
Now my final question is : I apply 10 equivalent radial efforts on the plastic piece resulting from the strap effort. If I want to convert this radial effort to a pressure, do you think I have to divide the radial force by the total plastic surface or by only 1/10 of this total surface (1/10 since I have 10 equivalent efforts on 1/10 of the total surface).
Thanks guy,
It's my ultimate question !!!
(10 loads ... 1/10th of the toatl area each sounds reasonable)
does the pressure need to be constant ??
(no, there could be some variation, but the distributions need to be symmetric)
Now my final question is : I apply 10 equivalent radial efforts on the plastic piece resulting from the strap effort. If I want to convert this radial effort to a pressure, do you think I have to divide the radial force by the total plastic surface or by only 1/10 of this total surface (1/10 since I have 10 equivalent efforts on 1/10 of the total surface)."
Frankly, I think you are making a mountain out of a mole hill.
Now since you further simplified the problem by proposing zero friction,the tensile force in the strap along the arc is constant, so it is clear that in any of your slices the general form of the solution still stands
pwr=T
P=T/wr
where w is now the width of the slice and T is the force in the elemental 'strap".
The remaining issue is if there is a gradient of strap tension in the depth direction which would allow different elemental T values at the different slices.
Do you really think that gradient is significant?
