vendors for tube conveyors/pipe conveyors
please help me in indentifying the vendors who can manufacture tubular/ pipe conveyors in India, for transporting slime/coal material through it over 33 m conveying distance.
what i understand is that the above tube conveyor is a multi-roll belt conveyor, with rolls arranged on the tube circumference and that the conveyor is totally enclosed/dust proof to the outside ambient atmosphere.
RE: vendors for tube conveyors/pipe conveyors
I used to work for svedala, and they made a few pipe conveyors. Try them, now metso minerals.
http://www.metsominerals.com/
JLN
I have seen these tube conveyors in South Africa. They often advertise in the Bulk Solids Handling magazine.
Try calling the University of Wollongong - Bulk Solids Handling unit at www.uow.edu.au/eng/bmh. They should know the Vendors operating in India.
Alternatively search under Bulk Solids Handling on the web. Sites such as www.powderbulkmg.com/scripts may give you a lead.
Even a direct call to a conveyor Vendor, such as Prok Technical Department will help.
dear JLN,
can u brief me
a)the construction of pipe conveyor and
b)how the material actually gets conveyed. Does it require any compressed air.
c)what all parameters are important for complete specification of pipe conveyor.
Hi mthota
The design is as you wrote yourself, belt is beeing guided with rollers, to make the belt round (pipe shaped)
loading an unloading is done as on a normal belt conveyor.
No use for compressed air, works as a normal conveyor, but without any spills and dust
About parameters and any technical stuff, sorry i dont know much about that, i was in charge of production.
But try to take a look on:
http://www.bulk-online.com
and make a serch for pipe conveyor
am sure they have some articles about the technical details.
Hope this help
JLN
The conveyor is a form of pipe conveyor. It comprises a wide belt which is guided to form a 360 deg cover with itself, by use of 6 idlers - 3 bottom troughing idlers and 3 top cover idlers. They are featured in Bulk Solids Handling Vol 22 (2002) No 3.
The following are vendors
1 - Bateman (South Africa)
2 - Koch (Germany)
3 - Noyes (France)
4 - Nova (Italy)
5 - Dosco (U.K)
6 - Simplicity (India)
7 - Krupp Robins (USA)
8 - Young Poony (Korea)
9 - Sistemas (South America)
As a rule of thumb they cost twice the cost of a conventional troughing belt conveyor. Worldwide the conveyors are less than 100 m in length and the carrying capacity is less than 100 t/h.
//dear sir,
     For pipe conveyors you can give enquiry to us on following address
SANGHAVI ENGINEERING
(BULK HANDLING DIVISION)
121,CIE,BALANAGAR EXPN,
GANDHINAGAR,HYDERABAD,
ANDHRA PRADESH,
INDIA .EMAIL: sanghavi@hd2.dot.net.in
fax: 0091-40-3086632
There is another kind of conveyor which has been called a tube conveyor. In this type of conveyor, a conventional conveyor belt is used, but the belt has rubber only on the load side of the belt, the back side being some kind of fabric so it can slide easily.
The conveyor frame is a steel tube, and the belt runs in the bottom of the tube.  Power is supplied to the belt in the conventional manner with a head pulley. The belt returns to the feed end of the conveyor outside the conveying tube, supported by return idlers, and perhaps in another tube.
This kind of conveyor can convey dusts like cement without exposing the cement to the environment, or the environment to the cement.
Hi Mthota
I may be able to give you some insight.
pgannon@rushmore.com
Dear Sir,
We have supplied a pipe conveyor for crushed coal in our coal handling system.
Length : 50 mtr.
dia    : 250mm
We are manufactures of Coal Handling System and special type of conveyors like
1. pipe conveyors
2. steep angle conveyors
3. troughed belt conveyor
4. package conveing system
You can send us your enquiry. If you wish to see the pipe conveyor in working then let me know we can arrange your visit.
thanks
Ketan Trivedi
Fairtech Engineering Co.
4306, IV phase GIDC Vapi
Gujarat 396195
PH : (0260) 427808 / 427809
e-mail : fairtech@indiatimes.com
