Static pressure of a closed loop system.
Hello all, first time poster here.
I need to find the static pressure of a closed loop wind tunnel. What equations will I be using to accomplish this?
The tunnel is 24" round ducting which nozzles down to 12" for a short section, then diffuses back to 24".
RE: Static pressure of a closed loop system.
thread403-180752: closed loop static pressure
You will have to have two of these variables to solve for the third.
Total pressure is the same.
