Admiralty brass and Chloride water
One of the Lube oil heat exchanger tubes material is Admiralty brass. We are planning to use cooling water having chloride of 350 ppm. Whether admiralty brass can be used for the above cooling water quality? Whether temperature rise in the cooling water will have any effect in the admiralty tubes?
Thanks to clarify
Thanks to clarify
RE: Admiralty brass and Chloride water
The temp. of the water shouldn't matter much.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
The usual 1-3 PPM are fine, but I have seen something (cannot find now) about problems at higher levels.
Another good source of informatin is www.copper.org especially here: http://w
rmw
Admiralty is nearly impervious to cl-, at least up to ~20,000 ppm. But 350 ppm of actual CHLORINE in water would make me perform some meaningful tests for suitability.
I don't think it was the chlorine per se that caused failures, but the decomposition products of the biomass, which include ammonia compounds.
What is the temperature range?
rmw
Addenda:
We welcome a dry spell as the water will get salty enough that we can pick very large white shrimp off the traveling screens. It is nothing to getting a 48 quarter cooler full in an hour.
