How to dimension slotted holes?
When trying to dimension a slotted hole in a drawing, the center mark command will only put a one center mark in the center of the slot and not the center of the two holes used to make the slot. How can I put both center marks in the slot in order to properly dimension it?
RE: How to dimension slotted holes?
I've tried that. It hasn't worked. I still get the one center mark in the center of the slot.
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
Also, there are 3 "proper" methods to dimension a slot in ASME Y14.5. SolidWorks supports all three. The default method that SolidWorks sets is to the center since this is the simplist scheme.
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
