6" SS Clamp Ferrule material selection
Dear All,
Can you help!!
habitually we fabricate Clamp Ferrule using Rod Bar SA-479-316 for 4" dia. and less,  UG-14(b)does not accept this material for 6" dia.I think to use piping material: SA-312-TP316 , So I can machine 6" pipe Sch80 to obtain 6" ferrule.IS IT CORRECT TO USE THIS MATERIAL. IF NO WHAT MATERIAL CAN I USE.THANKS VERY MUCH.LAURENT.
RE: 6" SS Clamp Ferrule material selection
As long as it has the SA designation it will be an ASME approved material. If in doubt check with your local AI for the specific application.
Laurent
Please read Code cases 2148-1 and 2156-1
Pressure parts from rods and bars UG14
larger than NPS 4"
