reducing hardness of 420 stainless steel.
Is there a way I can reduce hardness of 420 stainless steel in the form of 0.1mm thick and 12mm wide come in 16kg rolls.
RE: reducing hardness of 420 stainless steel.
Yes, Type 420 stainless steel can be annealed, or tempered at a higher temperature if this is spring steel strip.  Do you have an idea of what hardness/strength/ductility your application will require?
