Error Reoming component from assembly NX 6
We are getting an Error on one machine when trying to remove a component from assembly.
The Error is
Error recovery completed for the following error:
An operation was attempted on an invalid or unsuitable OM object
It works on everyone else's machine. WE changed the RAM on the machine and that doesn't seem to help. Does anyone have any suggestion what else it might be. All of our machines our Identical.
Thanks for the help
The Error is
Thanks for the help
RE: Error Reoming component from assembly NX 6
Granted that you know which component that you wish to remove (if you do try starting a second session), then you don't necessarily even have to have any components opened in order to remove one from the assembly.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
