SMPS with PFC?
SMPS with PFC?
SMPS with PFC?
We are in Maryland and we have an SMPS which is rated at 60W, and therefore it has a PFC front end.
However, the 60W output only occurs for one second  when 4 solonoids are operated.
-after that, the power draw never goes above 30W.
Its in a shower unit so the (normally-closed) solonoids only get activated once per day, per person, typically.
-after being activated, the solonoids draw the low level holding current.
-so should we really need the PFC stage?
RE: SMPS with PFC?
What is SMPS? PFC = Power Factor Control?  Why does a 60W load draw make it have power factor control?  Interesting.
RE: SMPS with PFC?
SMPS = switch-mode power supply. Correct on PFC.
RE: SMPS with PFC?
No you shouldn't really need PFC however, "rules" may dictate it.  That can happen when a location could have a bunch of something that will add up in power line harmonics.  For instance it's possible for a facility to have several hundred PCs.  Each may only draw a small amount that would normally not amount to any bothersome harmonics, but with hundreds, the harmonic can increase to a point that causes a lot of electrical problems with other equipment, the facility, or the utility.
So, we can't definitively say no you don't need PFC.
Keith Cress
