Rigidity center of inclined walls?
I just can't find the equations for rigidity center of inclined walls? Can you help me?
Thank you in advance
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Rigidity center of inclined walls?
Inclined in plan not in elevation!
This is plan view of few walls.
PS: I'm searchig for general expressions for rigidity center. Think that I found them:
Xr=Σi(Kyi*Xi)/ΣiKyi
Yr=Σi(Kxi*Yi)/ΣiKxi
I just have to add inclination koeficient?
I agree with ishvaaag that shearwall rigidities are vector quantities. Each of them can be represented in vector notation by a.i + b.j where i and j are unit vectors in the x and y direction. But, assuming the rigidity is the same in the opposite direction, which is usually true, then each of them can also be represented as -a.i -b.j.
Is there necessarily a single center of rigidity for an arbitrary group of walls? I would guess that the answer is no because some can act in the opposite direction. It depends upon the forces and the location of forces acting on them.
However, I have not thought it through, so do not want to commit to a particular answer at this moment. It is nearly midnight and I am going to bed. Nighty night.
BA
BAretired:
Yes, it's undependable from the load direction!
I believe you are correct. The method you indicated in your earlier post should be okay.
BA
