Pump selections
Pump selections
Seems as all the pump selection problems are now a thing of the past. All of us old guys can put away our pump books and slide rules and take up fishing or bird watching, then maybe there is still an opportunity for us to sort out some of the weird and wonderful questions posted in this and other forums that can't be solved by wiz-bang technology.
http:// pump-flo.c om/about-u s/press-ce nter/press -releases/ new-pump-f lo-premium -pump-sele ction-soft ware-now-a vailable-o nline.aspx
http://
RE: Pump selections
RE: Pump selections
A pump remains an engineered product. A selection software cannot and does not consider all aspects of a correct pump sizing.
RE: Pump selections
RE: Pump selections
Very comforting, isn't it?
Valuable advice from a professor many years ago: First, design for graceful failure. Everything we build will eventually fail, so we must strive to avoid injuries or secondary damage when that failure occurs. Only then can practicality and economics be properly considered.
RE: Pump selections
And I would have to strongly agree with CC and Tenpenny, without proper knowledge, pump flo could be less friend and more foe.
RE: Pump selections
One would hope the engineer has learnt all there is to know at www.mcnallyinstitute.com and more . Then they can go on to use the software as a guide.
Software is ony as good as the guy who prepared it.
RE: Pump selections
"I am sure it can be done. I've seen it on the internet." BigInch's favorite client.
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.live.com
