Imported materials used in Building Works
The Australian Steel Institute has published technical notes regarding the use of imported materials in structural works.
http ://www.ste el.org.au/ inside.asp ?ID=685&am p;pnav=401
If the large majority of bolts are being sourced from oversee's, should the engineering community be specifying that all bolt should be independently tested before they can be accepted on site.
Similarly with imported ply being incorrectly graded.
http://w ww.ewp.asn .au/newsan dmedia/new s_chinesep lanks.html
ht tp://www.e wp.asn.au/ newsandmed ia/downloa ds/media_r elease_-_a sian_plywo od_comes_u nstuck.pdf
http
http://w
ht
RE: Imported materials used in Building Works
An expert is a man who has made all the mistakes which can be made in a very narrow field
Thanks, what about steel and mill certificates?
