emf
emf
Looking for information on EMF sources within teh built environment. I have a situation where the clinet is concerned with EMF radiating from a 12kV feeder but is not concerned with EMF from a transformer (112.5kva - 480V - 208Y/120v)
Any resources out there that compares the different sources and voltages and their EMF influence?
Thanks.
b
RE: emf
EMF? Electro Motive Force?
Do you perhaps mean ELF? The thing people were concerned about some ten or twenty years ago - and some superstitious people still are.
Gunnar Englund
www.gke.org
RE: emf
Not sure where you have looked, but there should be a lot of information available.  This issue was studied to death back in the 1980s.  Software programs are available to calculate predicted field strength.
Proximity is a major factor as well as the magnitude of current.  An electric blanket is a bigger concern that a 12 kV feeder, unless it runs through your bedroom.
This is still a controversial issue, so tread lightly.
David Castor
www.cvoes.com
RE: emf
No light treading necessary. That will only create insecurity with people less informed and of a generally cautious nature. No need to give them food for angst.
Gunnar Englund
www.gke.org
RE: emf
I don't know about Sweden, but the angst is already there for a lot of people in the US, Gunnar.  I've seen consultants get shouted out of a meeting for stating that there is no proven danger from the power line outside.  Rational thinking is not always in evidence around here.
David Castor
www.cvoes.com
RE: emf
Same thing here. I am one of those that gets shouted at quite often. But I see no need to support that kind of thinking.
There is a society for reduction of superstition (Föreningen för vetenskap och folkbildning, Society for Science and Education of the Masses) that does a great job in these and neighbouring areas. Lots of shouting from people that think that we are paid by the utility companies.
Gunnar Englund
www.gke.org
RE: emf
Thanks. Any papers on how emi from transformers, MV lines, etc., impacts sensitive electronic equipment and rules of thumb for locating emi sources from sensitive electronic equipment?
RE: emf
Is it EMI now?
What exactly is your client worried about?
Gunnar Englund
www.gke.org
RE: emf
I used to be superstitious, but with proper counseling and the marvel of modern pharmaceuticals now I 'm only a little stitious.
