SOLIDWORKS DRAWING SCALE
I have scoured the internet, as well as spent countless hours fiddling in solid works for a solution to my problem below. I haven't had any luck, but I am sure this can be done. If anyone has any input it would be much appreciated!
I have done 100's of solid work design templates that automatically create models in solid works for our standard product lines. My next step is to automatically scale the drawings with the dimensions for manufacturing. I am having trouble scaling the parts from the model to the drawing. As I change the diameter in my model, the part in my drawing will become way to big or way to small and go off the page or is not readable. Is there a way I can link a scaling factor to my diameter dimension in solidworks or the design table. I have attached a design template for a simple O-Ring for reference.
Your file's link is: http://fi
Thank you,
David Sheets
RE: SOLIDWORKS DRAWING SCALE
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
I have looked into auto scaling. It would work by finding a scale that would be a ratio of a dimension of something on the part or assy (store that in the excell sheet or in the part/assy properties). That part is doable. Unfortunately, and the reason why I haven't done anything with this, it does not address the fact that the dimensions and verbage will be all over the place after doing this. Changing the scale takes significantly less time than fixing the other stuff. I have no ideas of how it would be possible or feasible to automate dimensions and verbage positions.
If anyone has any ideas how to automate the whole thing, that would be great. My guess is that it is not practical or feasibly possible.
John
ht
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
