Automatic Custom Property List creation?
I want to have an automatic list of custom properties created for each part that I can fill out when going to File -> Properties while building the part, instead of picking through the list of Property Name pull-down menu items for the same properties every time. However, I don't want to delete any from the Edit Custom Property List in case I want to use others later. So I just want each Part to have under the Custom tab a list of Property Names, e.g.
PartNo
Description
Material
Finish
DrawnBy
DrawnDate
Vendor
Then when I go to File -> Properties all I'd have to do is fill out the Value/Text Expression box instead of that PLUS hunting around for all the Property Name items from the pull-down menus.
Thank you!
PartNo
Description
Material
Finish
DrawnBy
DrawnDate
Vendor
Thank you!
RE: Automatic Custom Property List creation?
2. Add all those properties. No values needed.
3. Save as a template.
-handleman, CSWP (The new, easy test)
