Sewer Service Laterals and CIPP
I will be using CIPP to line VCP pipe. A lot of the services are bad and I need a way to connect ex. services to the CIPP (can't just cut our the CIPP to reinstate the service). I found Inserta Tee, which looks like what I need. Does anyone have experience with Inserta Tee or something similar? Other suggestions for making that connection?
Also, is there a good way to connect an HDPE service to the CIPP?
RE: Sewer Service Laterals and CIPP
http:
http:
You will have to make a cleanout to install the lateral liner.
You can probably make the connection to the HDPE with a Fernco rubber fitting.
Inserta Tee is great for open excavation. This repair/connection method cannot be done remotely.
