modeling colour
modeling colour
How can I set the colour of features as I am modeling them??
I am designing on a casting set to blue...
I want all the features I model to appear in red.
I know how to change them after the fact but I don't want to do that.
I also know how to set NX to get "new face properties" from the parent or the part defaults...
How do I set the part defaults???
Jay
Jay
RE: modeling colour
Preferences -> Object...
...but I suspect that that you're not going to get exactly what you want since NX doesn't work that way. The best you can do is to set your default color (per the workflow above) to RED (note that this is a Part Specific setting which means that if you're using a modeling tempalte part you will need to make the change there). Also go to...
Preferences -> Modeling...
...and change the 'New Face Properties from' to 'Part Defaults'. When you create your base casting it will start out as RED but you then immediately edit it, changing it's color to BLUE. Now when you add features, the new faces being created will now come in as RED, which is what you're looking for.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
RE: modeling colour
But I don't think it will work for me, seeing as I will be modelling many unique downstream operations, all of which I'd love to see in it's own colour.
I think I'll just use "CTRL-J" and edit each face as I design them.
Thanks!
J
RE: modeling colour
Actually, it does work exactly as I expect it to!!!
I changed the PREFERENCE > OBJECT to whatever colour I want, I change PREFERENCE > MODELING to "Part defaults" and it works like a charm.
The original casting colour is irrelevant and I can change the colour as often as I like!
Great!
Jay
RE: modeling colour
John R. Baker, P.E.
Industry Sector
Cypress, CA
