Proper Drafting Standards Documentation for startup companies
I'm trying to continue a previous thread discussing standards for military work.
thread1103-193705: Drawing standards only for Military work
I'm part of a small company that is doing defense contracting work, as part of my job, I was researching how drafting standards have changed, since I was learning engineering drafting in college (8 years ago?).
I noticed the new standard is ASME Y14.100 which was to work in conjuction with DoD standards (MIL-STD-100G).
Please let me know if there have been changes in the standards, or if I have purchased the wrong documents, or if there are additional documents with regards to drawing standards and documentation.
As a side note, purchasing the Y14.100-2004 book was $100 for 38 pages. Is this right or am I missing something?
RE: Proper Drafting Standards Documentation for startup companies
http://www.asme.org/Codes/
Here is a list of stds you should have:
http://c
I didn't see it listed here, but somewhere the whole set can be purchased.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Yq4.100 is just the top level spec which references a bunch of others.
Look through all the stds referenced in 14.100 and see which are most relevant if you don't want to get all of them. I routinely look at 14.24, 14.38, 14.3, 14.35, 14.6 & B1.1 and less frequently 14.1, 14.34
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
"It is essential that this Standard be used in close conjunction with ASME Y14.24, ASME Y14.34M, and ASME Y14.35M."
I was expecting the revision to have a more detailed explanation of the standards or combined other documents instead of providing a reference number.
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
True, forgot about that. Thanks.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Matt Lorono
i.e. buy 2 books instead of 1?
John-Paul Belanger
Geometric Learning Systems
Matt Lorono
