AISC Code Unity Check (Unbraced Length)
I am performing an AISC unity check per section H-2. I am trying to specify my unbraced length L (KL/r) in order to determine Pc for the axial compression buckling.
I have attached a sketch that shows configuration. I have a 5x5 tubing member that is supported along its entire length in the weak and strong axis via crimped plate and flat plate (note sketch attached). Is my unsupported length L 0?
Thanks in advance.
Thanks in advance.
RE: AISC Code Unity Check (Unbraced Length)
But your Lb wouldn't be L either. You could conservatively take it as L.
Would this act as an acceptable support to brace the 5x5 member shown?
Thanks.
If not, you should check the tube and plates as a composite section.
DaveAtkins
Thanks for the help!!!
To evaluate the strength and stiffness of the plate for bracing I would probably consider it to be similar to a diagonal brace that kicks out a a 45 degree angle towards the adjacent column. The effective width of the plate would be the difficult thing to establish. I would think it would be something like 25% of the distance between the two columns. But, that's just based on eye-balling it. Not sure if there is a more rational procedure for coming up with this value.
