create weldmet profile from layout sketch
Hi everybody!
Few days ago i started using layout sketches, so i am yet  discovering its possibilities.
I made a simple layout sketch with rectangle(for plate) and few lines (for stiffener profiles) within it. Then i made Part from rectangle block, Next i made a block from single line, then part from block and finally tried to create structural member from it but without success. How can i create this member anyway?
Thanks for advance!
RE: create weldmet profile from layout sketch
I confused by your explanation.  Can you post the part?  Are you trying to create a weldment model or a custom welment profile?
Dan
www.eltronresearch.com
Dan's Blog
Create your layout sketch. Use the weldment features to create your structural members. Your best bet is to go through the tutorials in the help section.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Sorry for the confusing explanation.
Previously i tried to make a weldmet structural member on a simple plate(using layout sketch), finally i made structural member with following steps:
In layout sketch i draw line->made block from it->part from block->Open Part->explode block->structural member.
