Forcing a diameter dimension in a detail view
In NX4 I have a couple detail views (the little circular window) of a cylindrical part side view.
I can't figure out how to force a diameter dimension.  I can select one side, but the other side is outside the circular window, so all I an get is the radius (the 4.235 dimension in the attached JPG).  I want an 8.47 dia.
Is this possible?
RE: Forcing a diameter dimension in a detail view
Yes, a few ways.  Pick the opposite edge in another view and turn off the dimension and extension lines as well as the arrow on that side.  If another view is not available, enlarge the detail boundaries until you can see theopposite edge, apply dimension and resize view to original size.
You can also pick the edge then the centerline (in whatever view is available) to produce a cylindrical dimension.  You still have to edit the dimension lines though.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Thanks Eric.  Worked like a charm!
Your welcome.
Do I know you?  Eerie...
