Mesh part to geometry part
Hi I am trying to convert an orphan mesh part to a geometric part. I have tried in Abaqus but I don't think it is possible. I am using CUBIT 12.0 to remesh the mesh part in question but it also is unable to create a geometric part. Does anyone know of any software that is capable of doing this?
RE: Mesh part to geometry part
You would probably need a point cloud tool in a CAD package to get a NURBS surface model.  If you are OK with an STL, that should be an easy translation of the exterior triangles or squares.  I hope this helps.
Rob Stupplebeen
Rob
Could you please tell me what STL stands for? Thanks.
Ning
Search "STL CAD"
Below is the text file format for an ASCII formatted STL taken from:
http://en.wikipedia.org/wiki/STL_%28file_format%29
 facet normal ni nj nk
   outer loop
     vertex v1x v1y v1z
     vertex v2x v2y v2z
     vertex v3x v3y v3z'
   endloop
 endfacet
Basically define a triangle by the coordinates of the verticies.  Repeat for each triangle.  It looks like a poorly formatted FEA mesh.
I hope this helps.
Rob Stupplebeen
geomagic studio does that, but it's quite costly... ordinary cad packages (apart from MAYBE catia, nx) can't do that (without custom - costly - addons)
