Multi body part meshing
In workbench, is the any way to mesh a single body of a multibody part without meshing the entire part. Any help would be greatly appreciated.
RE: Multi body part meshing
The only way to mesh a piece of the entire part, is to suppress all the other parts. However, even though this can be useful for finding problems, do not expect that the mesh on the individual piece will be the same when you do mesh the entire part.
I had some idea that it would change, I just didn't want to let it run for 15 hours meshing to find out that i had a bunch of problems.
Thank you for your help.
you can supress other bodies and do preview mesg
