How to Rewrite/Use Excel Nested IF Function in Mathcad 14
I am trying to derive a nominal value from a Mathcad result using nested IF functions. I can do this in Excel but am not clear on how, or if, this is possible in Mathcad. Has anyone tackled this issue and can offer some much appreciated assistance?
Here is original formula:
tbh:= (P + PAs) * OD / (2 * Sbh * Eh) + (1.8 * (P + PAs))
where, P=150 psi; PAs=0 psi; OD=96 in; Sbh=20000; Eh=1
Here is Mathcad result:
tbh = 0.357586 * in
Here is Excel function formula trying to replicate in Mathcad:
IF((tbh+0.0625)<=0.25,0,0.25,IF(tbh+0.0625>0.25,((ROUNDUP(tbh*16,0))+1)/16,"Error"))
Here is desired result: tbh_nom = 7/16 * in (fractional with units is desired output)
Thanks in advance for your help...
tbh = 0.357586 * in
RE: How to Rewrite/Use Excel Nested IF Function in Mathcad 14
The only differences are:
> Need to add units to each 0.625 and 0.25
> use Ceil instead of Roundup
> divide expression within Ceil by inches
> multiply entire Ceil calculation by inches
> Format Result to display fractions
see attached:
http://f
TTFN
Next time, just post the worksheet. Transcription from text format is for the birds...
TTFN
