Inserting a component
Hello
I'm fairly new to Pro engineer, I am trying to add a component to an assembly and when I try to pick the constraints the view changes from the normal view to a wire frame view which only highlights an edge when you move over it. This never happened at first and I was wondering if I had inadvertently changed a setting. Is there a setting to change this back? I have added a couple of pdfs to show what I mean as it probably isn't very clear.
