At what size do emergency / service generators require pre-lube pumps
I would like to know what is the threshold value at which the service and emergency generators typically have a pre-lube pumps.
By the way, I am typically involved with land-based units under 60 kW. We do not have such pre-lube pumps.
Thank you
Thank you
RE: At what size do emergency / service generators require pre-lube pumps
Most of the yacht generators with which I have dealt, Diesels between 40 and 250 kWE, don't have prelube pumps.
All of the oil rig generators with which I have dealt, mostly natural gas engines 40kWE and above, do have prelube pumps, and oil heaters, which are run on a regular basis to keep the crank and oil warm.
Mike Halloran
Pembroke Pines, FL, USA
I don't think I have seen anything above 500kW without
I have worked on a lot of shore based sets, both standby and prime power. Size range up to about 1.2 megaWatts. I haven't seen a pre-lube system. I see some crank-case heaters and most turbos have a cool-down stopping sequence.
Bill
"Why not the best?"
Jimmy Carter
the "damage" done on each start depends upon time required to pressure the lube manifold (viscosity,lenght suction pipe,wear lube pump,...)
"..the more, the merrier" Genghis Khan
