stacked dimensioning standard
For decades I have used stacked dimension tolerances with the top dimension being the dimension the machinist comes to first. See example from attached text book. Now I have been told that ISO uses the highest dimension at the top always. Is this true? Is ISO diffrent than ANSI?
RE: stacked dimensioning standard
(a) Limit Dimensioning. The high limit (maximum value is placed above the low limit (minimum value).
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
"They still use dimensions with arrow heads at each end?"
When are they 'not' dimensioned with arrows at each end?
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
When are they 'not' dimensioned with arrows at each end?"
Was just a joke cuz of my advance years in the trade and not keeping up with the current trends and standards, although I've used and seen ticks, slashes, dots, etc. at the end of dimensions. :)
I once saw a flower petal on the end of dim lines!
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Per ISO 406 (1987):
The upper deviation or the upper limit of size shall be written in the upper position and the lower deviation or lower limit of size in the lower position, irrespective of whether a hole or a shaft is toleranced.
